Denon dvd-3910 region free, how?
Discussion in 'Blu-ray & DVD Players & Recorders' started by wakawanha, Sep 26, 2004.
  1. wakawanha
    wakawanha
    Sep 25, 2003
    16
    Where to get region free software to 3910?
    I quess is just a firmware update. Anyone have this?
    Or can it be done via remote somehow?
    Pete
  2. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    I dont think Denons can be done by remote, but there is a firmware update and I was promised a copy by somone. I could send u a copy too or u can ask this person yourself.
    "Messiah" is his or her name. You can read my previous thread on the second page. Called "DVD player chipping" by AML
  3. Radiohead
    Radiohead
    Dec 24, 2001
    4,380
    Amazingstoke
    +431
    Take it to a dealer to do - I'd be a little bit wary about applying firmware myself to a £1000 player....
  4. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    it realy easy to do the firmware upgrade....just dont turn the machine off while its updating....
  5. Andyuk911
    Andyuk911
    Sep 11, 2004
    427
    +11
    It is not out yet, but will be soon, I was told by a dealer. I have a 3910:)
  6. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    Mine arrived with MR. only gold dealers have it at present
  7. Andyuk911
    Andyuk911
    Sep 11, 2004
    427
    +11
    Interesting, I will have to phone
  8. wakawanha
    wakawanha
    Sep 25, 2003
    16
    Is it working ok? I have read some reports that region free is working fine,
    but after update there has been some difficulties with audio.
    Pete
  9. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    Had it now a few weeks and have had no problems yet,
    No audio issues.
    I must of sent the firmware out to about 15 people and have not had any complaints either
  10. wakawanha
    wakawanha
    Sep 25, 2003
    16
    OK, good to know!
    Can you send it to me also?
    Pete
  11. nelius
    nelius
    Gandley, where did you get the multiregion firmware? I'm searching for one for the 1910. Don't suppose you or anyone else has info about this?
  12. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    I got the firmware from my dealer who sold me the 3910.
    They are gold dealers so got the firmware very quickly.
    wakawanha send me a PM with your personnel email address and i`ll send the firmware on to you. the attachment file is 2mb
  13. ninja.rogue
    ninja.rogue
    @ gandley
    Hi Gandley,
    have you had any hi-rez audio problems?
    I mean, have you experienced any of the firewire and i-link problems that other people with mr 3910 have experienced here?
    http://www.avforums.com/forums/showthread.php?t=154593
    Thank you.
    I will wait for your reply before buying an already SDI-modded 3910 unit.
    Paolo
  14. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    I think those two guys got the fw from me and i have not expericed those problems exactly. I did need to disconnect the dvd player from the amp after i had made the fw upgrade, unasign i-link on the amp side....then reinstall and then i-link worked fine.
  15. ninja.rogue
    ninja.rogue
    Thank you very much.
    You are saying that your pre-amp needed to setup again with a new i-link source, aren't you? in this case it should be just a matter of recognizing the same input again...
  16. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    yep thats it
  17. Lizzard
    Lizzard
    I have received response from Denon how to check the firmware in the player.
    From Denon's reply to my e-mail:
    To confirm the software version on the DVD3910:
    1. Turn the small power button off on the front of the unit.
    2. Hold down the PLAY and OPEN/CLOSE buttons on the front of the unit, both at the same time.
    3. Turn the power back on and continue holding the buttons for 3 seconds, then let go.
    4. After “>II LOADING” shows on the display, press the 3,2,6,5 buttons on the remote (in that order) and then press the MENU button to see the version.
    Could you all please type your values here and then we can compare to each others.
    My values are and it's not regionfree yet:
    ESS 6609-5
    Make Day 831
    DRV 030825
    System 6767-2
    DSP 6770
    CNE 20040609
  18. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    Mine is exactly the same and is MR, so no changes except for adding MR.
  19. Lizzard
    Lizzard
    Thanks, i flashed it and it says the exact version numbers as i posted above but with the exception it's regionfree now.
    Excellent.
  20. paulefox
    paulefox
    Feb 8, 2003
    1,343
    Bury St Edmunds
    +44
    do the current models in the shops already have denon link 3 on them so that I can play sacds through the denon link lead
    also is the region free upgrade rce compatable
  21. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    No, current versions have Denon Link 2 only. Denon are still negotiating the rights to SACD over Denon Link and when sorted both player and amp will need to be returned for upgrade. (That's what Denon CS told me anyway)
  22. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    Yes to RCE, no probs with those discs
  23. motoguzz1
    motoguzz1
    I too need the code free software for this machine, can anyone help?
  24. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    Check the DVD hacks forum (just below this one) - there is a whole thread regarding this - including a link to the firmware.
