Denon DVD-3910 Image Cropping Issues-
Discussion in 'Blu-ray & DVD Players & Recorders' started by Spero D., Oct 12, 2004.
  1. Spero D.
    Spero D.
    I got my DVD-3910 today and am having a few issues. The major one is pixel cropping on my Marantz VP-12S3. I am using 720p to the S3 via DVI.
    When playing Blade the image comes in on the right of my screen about an inch.
    When playing blade 2 the image comes in from the sides slightly and is a 1/2 inch off from the bottom even though the menus fill the screen.
    Blackrain also doesn't fill the screen properly.
    With Different movies the image is cropped differently.
    The image is great and I don't want to get rid of this player but I hope you can shed some light on this problem.
    Is there a firmware fix for this problem?
    Spero
  2. paulw77
    paulw77
    Nov 18, 2000
    602
    28
    Wigan
    +48
    This seems to be an issue with the new Denon players - see my separate thread on the 1910 :
    http://www.avforums.com/forums/showthread.php?t=154329
    I would urge you to contact Denon - as they either deny this problem exists, or they blame the display. The have said they will work on a firmware fix if more poeple contact them.
