Skuffen Huffen
I am hoping someone can help please.
I have a Denon DVD-3910 and a Sanyo PLVZ5 projector.
I am using a 5m QED HDMI cable to connect the two.
When i hook the dvd up to the projector i get no signal, it doesn't matter what settings i use, it doesnt work, and then after a while the DVD player hangs and the only thing i can do it power it off. It wont go into standby, eject the tray, anything...
if i hook it up to my Plazma TV using the same cable, its absoloutly fine..no problems at all....
any idea what's going on...
