Denon DVD-3800
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kirk, Aug 1, 2002.
  1. Kirk
    Kirk
    Jul 2, 2002
    309
    Somewhere on t'internet
    Hiya,
    Has anyone heard any news on getting this player sourced from the UK in multi-region guise?
    And, dare I say it....PAL prog enabled?!?!
  2. Guest
    and chroma bug free don't forget...
    Andy
  3. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    I think all the UK retailers are waiting with bated breath for the multi-region hacked PAL progressive firmware.
    No matter what you are told otherwise, they are ALL waiting for the same firmware...I've heard my local Sevenoaks boasting that they would have the 'best' region-free solution (and charge £75 for the privilage!!!!).
    All 3800 hacks are equal unless they also provide macrovision off like the www.dvdupgrades.ch hack.
    Either way I am getting a bit impatient. I hope the delay has been to incorporate the latest chroma-bug fixes.
    Regards,
    Ian Guinan
  4. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    p.s.
    www.avland.co.uk seem to be a good place to keep an eye out for a UK source for multi-region Denon. Their website currently has '??' next to region mod, but watch this space.
    Regards,
    Ian Guinan
  5. Kirk
    Kirk
    Jul 2, 2002
    309
    Ahhh knackers!!! This is turning into a circus trying to get a decent mid to high end DVD with component prog scan output and mult-region.
    I want....i think:
    Denon 2800 MKII
    Denon 3800
    Pioneer 747
    But, and typically...its a big but (not always a bad thing, J-Lo for instance:D )
    They all seem to hae a draw back......I can just about let PAL prog slide for a while until it is "legalised", but the decent multiregion bit seems to be mission impossible at the mo........and I aint spunking up over £1000 for a DVD :)
    Ho-Hum
    thanks for the feedback anyway chaps
  6. Guest
    Don't discount the Philips 962SA, NTSC & PAL progressive and SACD , fantastic picture quality, well worth considering..
    Andy.
  7. WSquared
    WSquared
    Jan 31, 2001
    215
    Bristol, UK
    +3
    The non-European version 962sa that is, ie no scart.
  8. Guest
    Could someone please clarify the position with getting hold of a multi region denon 2800mk2 or 3800?
    sevenoaks are working one it (according to my local shop)
    www.dvdupgrades.ch seem to be offer a kit upgrade(has anyone tried it?
    cheers
    Gary
