Denon DVD 2200 layer change sound problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by supersub, Jan 25, 2005.
  1. supersub
    supersub
    Mar 14, 2004
    34
    Lincoln
    Hi all,
    i've recently upgraded my dvd to the Denon 2200 there is no problem with the picture when going through a layer change on a dvd, but recently there has been a sound gap and i'm presuming that this is caused by a layer change,
    has any one had similar problems or knows of a fix?
  2. shortround
    shortround
    Sep 3, 2003
    418
    28
    +43
    are you certain this is occurring at the layer change? are you testing it with discs that you KNOW where the layer change is? what sound setup/outputs are you using? i've heard people complain of sound dropouts with denons before, i think usually with DTS.
  3. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    Not had any problems at all with layer changes. I've had the odd DTS sound and picture drop out though and no drop outs with Dolby Digital.
  4. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,413
    In a secret location with Jennifer Lawrence
    +7,245
    Don't these Denons have buffer to prevent you seeing a layer change? I know my 2900 does.
  5. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    Yes, mine has 8MB, like yours, the lower models have 2MB, which isn't enough, as I had one.
