Denon DVD 2200 and disc labels
Discussion in 'Blu-ray & DVD Players & Recorders' started by markg1811, Dec 27, 2004.
  1. markg1811
    markg1811
    Dec 11, 2002
    15
    I've had my Denon 2200 for a couple of months now and have been very happy with it until now...
    When I play a home burned DVD with an adhesive label attached to the disc, the screen locks up after approximately 10 mins. It works fine with home burned DVDs without labels and all pre-recorded discs. These discs worked on my old DVD player so I know they're fine.
    Has anyone else had this problem and know of a fix for it (firmware?)?
  2. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    Dont use sticky labels on any disc media. Its like adding a balance weight and as dvd discs spin faster a sensitive drive will not like it and become unstable.(and denon drives tend to be very sensitive)
    Use a printer that can print to a CD/DVD. Using sticky labels will shorten a drives life or kill it. Not wise at all
    There is no firmware fix, to allow the use of sticky labels(be honest you new that already didnt u)Its very bad practice. Use a marker, its much safer
