Canned
Hi.
I read this topic about a DVD-1930 with a noisy drive mechanism. I have a Denon DVD-1940 with, I guess, a similar problem. It has a really noisy disk hum-cum-rattle as the DVD spins at speed. I can hear it from the other side of the room. Really pointless is buy expensive players & amps if you have to bury the noise of them by cranking the speakers up!
Is there a fix for it? It's sounds far worse than the cheapest PC DVD drive I've heard.
Thank you in advance.
