Denon DVD-1920 multiregion hack is here
Stuart Wright
AVForums Founder
Staff member
We take no responsibility and accept no liability for any damage caused by applying this hack. Use it at your own risk!
First of all, download the Word document instructions here .
Then download the firmware file from here .
OK, what you need to do is burn the downloaded data file E61E2ED117D0.abd to a CD-R at 4x speed.
Make sure the disc is finalized - your CD burner software may state this as a closed session or a non multi session.
Then follow the Word document instructions.
I have successfully applied this hack myself.
SuperSeven
I doubt this a newer firmware, just the current firmware but region free.
My player came region free from retailer.
Is there a way to get the player to tell me the current version number?
Algoz
chez said:
What version of the firmware is this?
Chez - have you tried this upgrade? Work ok for you? I am nervous in case it screws up my machine....
Paul
chez
No, mine came multi-region, just wanted to work out whether this is newer or older than what I have..
Algoz
Stuart - this file extension is ABD. There is another file on this forum with an extension of ISO. What is the difference?
Tks
Paul
chez
The .iso will be a disc image, rather than just the file that you require
Algoz
Thanks for the reply Stuart - I therefore presume I should use your .ABD file as the .ISO file is not actually the correct format and simply an image?
Ta for your advice.
Algoz
Stuart - after you had applied the firmware, did the DVD retain it's ability to output HDMI(upscaling)? I am concerned about losing this, as it was the main reason I bought this machine last week!
Paul
Algoz
Paul
hillster
Paul
I received my firmware upgrade from Peter Tyson, I assume it's the same as this one. I'm still using the HDMI output (720p).
J
Jezus
Hello ppl!
I recenly got the Denon 1920 player and a Hitachi 32LD6200 LCD TV.
The thing is that the DVI port on the TV does not support HDCP copy protection, so I cant use a digital connection between the Denon and the Hitachi (HDMI to DVI). Do you know if this firmware also unlocks the HDCP protection on the Denon, or if such firmware exists?
Thanks for your time,
Kostas
J
Jezus
Jezus said:
Hello ppl!
Kostas
It apears that noone knows f there's a solution to my problem... it seems that I should go out on a quest for another DVD player, with a HDCP-free DVI port, and spend my hard-earned cash on it... damn salesmen, they swear that my set-up will work properly, and so I ended up buying stuff that's useless to me...
chez
Why don't you go back to the shop you bought it from (who advised you incorrectly) and ask for a refund/different player/tv?
J
Jezus
Actually, it took me 3 visits to the shop (it is located in another city), and many phonecalls to the shop and the importers to convince them that such problem DOES exist, and the problem is not my cables/setup/connections/brain/whatever.
They are probably going to hand me a new player, the thing is that I need a player with a HDCP-free DVI port that will also play my SACD and DVD-A discs, and there are not many of them going around these days... Maybe I can get a low-priced DVD player with a DVI port, and keep the denon for SACD/DVDA playback purposes... but then, that doesnt seem like the best solution, for many reasons...
skipton01
Does this hack/firmware enable upscaling at the component outputs?
Please say yes (unless of course the answer is no!) because I don't really want to buy a Samsung or LG (Goldstar anyone?). It would slot in nicely with my other Denon kit too!
Kind Regards,
Mike
byron_hinson
Any versions above 1.17 yet?
3dgs
from remote control press 1234 and DISPLAY keys remove any disc from player before...exit is Power off,factory defaults CLEAR
B
boyolayton
I've just tried to apply the hack, but a few seconds after inserting the CD-R, I get a disc error on the Firmware Update.
Any ideas?
Eddy Boy
I would suggest you change the TV for one with HDCP, has once HD sky and other formats come out you'll be stuffed.
k_jartti
I have version 1.17 also, but after that in the same line, there is "d1.0". Do you have same marking? What does it mean?
aerotec
Well I just installed this on my 1920. Supplied Region 2 Version 2.0 but this made it region free 1.17. Had a look through the menu and all seems the same and still upscales nicely to my 436XDE.
Not sure what changes there were between 1.17 and 2.0.
Hmmm, still it worked for me and now Multi-Region.
Would be handy if anyone who bought a Multiregion unit could check the version and let us know what it came supplied with.
Similar threads
Latest News
Acoustic Energy launches AE520 flagship speakers
  • By Andy Bassett
  • Published
Disney drops all 20th Century Fox branding
  • By Andy Bassett
  • Published
Kitsound launches Funk 25 wireless earphones
  • By Andy Bassett
  • Published
THX Spatial Audio app brings 360 degree sound to any headphone
  • By Andy Bassett
  • Published
Xbox Series X November launch confirmed
  • By Andy Bassett
  • Published
