Denon DVD-1910 through DVI...Not that impressed! WHY?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Oakleyspatz, Apr 13, 2005.
  1. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    Ok, so I've been using a modest Panasonic DVD-S75 through component to my Infocus Screenplay 4805 and have been very pleased with the resulting image. Sharp, great colours, excellent contrast and rock solid image. But I've been reading so much about how a DVI connection is the ultimate method of image connection that I had to get a Denon DVD-1910.
    Connected it up and selected first a 1080i output so as to take advantage of the slightly superior Faroudja in the 4805 compared to the lower spec Faroudja in the 1910. Result? Crap! The image 'shimmered' constantly and looked much worse than through the Panasonic. Next I tried 480p output. Result? Nearly as crap! The image was 'masked' on the sides by a kind of 'blurred frame'. Almost as if someone had placed their hands at the sides of the lens. Then tried 720p and I finally had an image which looked closest to my Panny but it still didn't have quite the impact. Colours where much more subtle, almost pastel in appearence. I went into my 4805's menu to boost the colours but that option was not there through DVI!!? Weird.
    Detail? No better than the Panasonic. I was expecting this massive jump in image detail which just wasn't there.
    So, I was not impressed at all with the Denon and have since sold it. I think the lessons learnt are:
    1) My Panasonic is a superb budget DVD player
    2) The Denon is wasted on a display that doesn't have a HD resolution of at least 720p
    3) Component is not as far away from DVI as some would have you believe.
    One plus point on the Denon, I never saw any Macroblocking that people have mentioned !
  2. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Sorry to hear that Danny. Interesting never the less. Maybe it is something to do with the 1910 being Denons budget deck.
    Can you return it?
    Pete.
  3. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    :offtopic: Pete how are you getting on with the Pioneer?
    I Have the Panasonic S97 and have updated the firmware to 536 but it still suffers from macroblocking :(
    Adrenochrome.
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    Hi Oaks
    I don't know if you've read my recent comparisons but I've similarly been slightly disappointed comparing my newly acquired Samsung 745 via DVI with my existing Pio 575 via component.
    Via DVI I don't get any shimmering effects you descibe, to be honest all DVI resolutions look clean and fine (one of them flips to 4:3 AR but I think that's as designed).
    But the Sammy is not quite as sharp as the Pio. Colours are deeper though. The picture is darker hence I need to adjust things to retain the image's "snap".
    I definitely prefer the Pio.
    I must admit I tried not to get my hopes up for DVI, mainly because I'm using a 15m cable. I either thought I'd get problems, or it would work fine and the pic would be stunning. I didn't count on it working fine and the pic not being quite as sharp. That said, the Pio on my TX has amazing clarity - and I did find it difficult to imagine anything giving me a significant improvement....PJ :)
    PS Similar to you, using DVI reduces the amount of control I have on the TX over the image eg colour
    PPS the Sammy via component looks :thumbsdow
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    I always recommend you don't use the scaling function of these players, particularly the Denon. Output in 576p or 480p is best in my experience. Let the projector do all the scaling (which most of them are actually quite good at).
  6. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Tom, as before, not wishing to take Dans thread off topic but the Pioneer 868 is superb. The picture quality via 720 hdmi is great. Loads of detail and great colour. Very, very pleased.
    However, some things I have noted are ~
    a. It is not as good at spinning music as my Denon 2900, though a standard CD via Firewire is very detailed when played in 5 channel stereo.
    b. the remote is as bad as we established at the Bristol show :suicide:
    c. The denon range are superior build, in my humble opinion
    However, ultimately its about PQ and the 868 has it in spades, whether connected via HDMI or Component progressive :smashin:
    Pete
  7. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    Yes I think you are right. What I'm most surprised is how little, if any, benefit is gained by removing the D->A->D stages from the signal path...PJ
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    PJ
    I have seen some pretty hideous things with Denon players upscaling. The built in scaling is pretty iffy in my book. I think they have bandwidth issues. 480p / 576p can look wonderful however.
    As someone who is fussy about quality I had similar reservations but looking at the DVI output of a Tag (AD DA) then I soon realised it is how you do the engineering that matters. The AD stages are generally very good, where you start having problems is the transmission and DA stages.
  9. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    Comparing 480p/576p on the Samsung (DVI and Component) against the upscaled images, I reckon upscaling is significantly better. Sharper, crisper and reduced artifacts. Likewise with other scaling players I have tried.
    Also just to contradict PJ (again) the component picture on the Samsung is very good on my set up (especially @1080i). See other threads on 745/945's to back it up.
    Also remember the PIO 575 has its fair share of critics regarding its PAL PQ (jagged edges).
    The Denon 1910 (IMHO) had a very good DVI PQ, but macroblocking was evident when I tried the player.
    I surmise the player / display combination must be a big factor to explain these differences of opinions.
  10. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    I think the player / display combination is everything.
    That's why I keep saying "on my setup".
    But I remain surprised how much better the standard 480p/576p component PQ on the Pio looks than any of the res's on the component Sammy output. I mean, it's chalk and cheese. Same cable by the way. On my setup. :) ...PJ
