Z
Zooben
Long time lurker and first post...
My setup consists of the following:
Panasonic TH-42PW7B
Slot 1: DVI-D
Slot 2: SCART
Slot 3: Component BNC
Denon DVD-1910 (Firmware 1.09)
I am trying to set up the 1910 via DVI and am having difficulty in getting a stable and high quality picture. Once I realised I was having problems I did some searching around (I know I should have done this first) and have come across all sorts of people having the same problem as me - something to do with scaling(?) and what format the 1910 is sending out and what the DVI board in the plasma can receive.
A picture can only be obtained by multiple pressing of the DVI button on the player itself. Sometimes the picture appears, but only to vanish some seconds later. On the rare occasion that I do get a picture, the quality is so poor it is almost unwatchable.
There have been rumours of a 1910 firmware update (1.10), but I have not read anything to say that this has fixed any of these issues.
After my research I am pretty much resigned to swapping out the 1910 for an alternative unless you kind people can point me in a direction that will help, either by way of a possible fix or a different DVD player with DVI out?
Thanks in advance.
Zooben
Panasonic TH-42PW7B
Slot 1: DVI-D
Slot 2: SCART
Thanks in advance.
Zooben
