Denon DVD-1910 and DVD+R Double Layer
Discussion in 'Blu-ray & DVD Players & Recorders' started by geekp, Feb 26, 2005.
  1. geekp
    geekp
    I have the Denon DVD-1910 (firmware 1.10). There is no way to play DVD+R Double Layer (tried Verbatim and Ricoh) recorded with good Dvd writers and checked for errors with PI/PO tests with Plextor PX-712A and Plextools (all discs have a very low rate of PIE errors and no POF).
    Any experience out there with Double Layer?
    Ciao
    Sergio
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Did you bit-set them to DVD-ROM? I know my Pio 868 won't play them unless I do that on my NEC writer. I don't see +R9 listed in the 1910's specs on Denon's site.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    23,165
    Warwick
    +3,779
    I appreciate it's not the same model, but my Denon 3910 plays DVD+R DL without any problems whatsoever. All recorded with DVD-ROM book type on an LG4120 or LG4163 and authored/burnt with TMPG Encoder Author.
  4. geekp
    geekp
    I have tried with Verbatim and Ricoh DVD+R9: book type DVD-ROM, discs recorded with good DVD writers (TDK 1616N and Pioneer DVR-108), Nero Buring ROM 6.6.0.3 and latest 6.6.0.8 and very good results in PI/PO tests with Plextor PX-712A and Plextools Professional 2.19A.
  5. Loewe
    Loewe
    Have anybody played DVD+R DL on 1910 with good result? Are there more people with bad experience with this? Will firmare 1.12 correct the problem (or what does it do)? Are most other players compatible with Double Layer?
  6. yrat
    yrat
    Mar 19, 2008
    Have the same problem with 1940. So I'm going to return the unit (unfortunately).
  7. yrat
    yrat
    Mar 19, 2008
    PS: Does anybody try DVD-R DL ?
