I have a Denon AVR-4308CI. I just purchased Denon DVD-1800 BD blue ray dvd player. The player's spec in denon's web site says "features support for the latest generation high resolution audio formats, including Dolby TrueHD and Dolby Digital Plus as well as DTS-HD Master Audio soundtracks."
But after reading may reviews of this product, I saw that it does not have built in decoders for these audio formats. In one of the web sites I saw this.
I don't understand what this means.
- If the DVD player decodes Dolby Digital and DTS to PCM, will the receiver still output DTS and Dolby digital audio quality?
- If the DVD player outputs bitstream audio for TrueHD and DTS-HD, will 4308CI decode these as TrueHD and DTS-HD?
I guess, my question is since the DVD player can output only PCM and bitstreams, will the audio quality be same as TrueHD, DTS-HD, Dolby Digital etc. Does this mean that the A/V receiver is decoding these audio formats?
Which is better - Having a DVD player with built in decoders or a A/V reciver like 4308CI that can decode these formats?
Anand
- built-in audio decoding to PCM for Dolby Digital and DTS
- multichannnel uncompressed PCM output via HDMI
- bitstream audio output via HDMI for Dolby Digital Plus, Dolby TrueHD, and DTS-HD Master Audio
Anand
