Denon DVD 1000 Region Settings?
Discussion in 'Blu-ray & DVD Players & Recorders' started by blueferre, Mar 29, 2001.
  1. blueferre
    blueferre
    Anyone knows how to change Regional settings on this DVD?Can't play Matrix Hollow man etc etc....
  2. Guest
    This player isnt multi-region unless it has been modified, If yours has a hardware mod then check with the people that installed the mod to find out how to change settings.
  3. nickoff
    nickoff
    Hey blueferre, how does the Denon dvd-1000 perform?
  4. Guest
    I had a denon 1000 for three weeks and I took it back because it had a unacceptable lip sync problem.
    I am now the proud owner of a Toshiba sd200e.
