Denon DRA-1802 Receiver gain problems ?
Discussion in 'AV Receivers & Amplifiers' started by fender62, Jun 29, 2005.
Tags:
  1. fender62
    fender62
    Jan 11, 2005
    144
    19
    cowbridge
    Denon DRA-1802 Receiver problem
    It works perfectly when used with digital sources. That means that if you use DVD, SKY plus, PS2 and other digital sources, the faults will not effect you. However, when you use analogue connections there is a substantial loss of gain or volume. any idea wha tthe problem might be what sort of repiar might it need
