Hi, I'm thinking about getting a 4th Gen Ipod Touch but not sure if the DM38 is compatible with this using the USB port. I've tried to look at the manual online but it just says compatible with Ipod/Iphone?
From the manual:
• To connect an iPod to this unit, use the iPod cable supplied with the
iPod.
• With this unit, playback via iPod (5th generation or later), iPod touch,
iPod classic, or iPod nano can be performed. For details, check the
Web (Denon Global | Please choose your Denon region
I have used a 2nd gen Touch to stream over wireless without issue.
