mrmcdean
Quick question for you all,
Im about to get a Denon DM31 to go in the bedroom, I also have a record deck which wont fit on my system downstairs so was wondering if I could hook it up to the Denon. I know you're not supposed to hook up anything other than a record player to the phono connections on an amp, is the opposite also true ? Am I OK to hook up a record dec to a set of Aux. inputs ?? (im pretty sure that the Denon has them)
Any help would be appreciated, ive only just managed to convince the other half that her old Aiwa is past its prime, the last thing I want to do is blow up a new stereo.
