Denon DHT550SD connections - please advise...
Discussion in 'Home Cinema Buying & Building' started by Samwise, Jul 28, 2005.
  1. Samwise
    Samwise
    Hi all,
    I have taken the jump and bought the Denon DHT550SD, from Peter Tyson - £600 - including speaker stands and delivery. Plus very helpful. Would highly recommend the Peter Tyson phone sales and technical help to anyone.
    I have not bought any new connections yet. So would like some advice on what cables to buy?
    I want to upgrade to component connections as my TV (Toshiba 32ZP48) has the connections I think.
    Plus I want surround sound from my free view box and XBox.
    How do I connect these all with the Denon?
    What are the best connection cables for this job?
    Thank you for any help in advance...
  2. MattyKHZ
    MattyKHZ
    Jan 15, 2005
    303
    +24
    Optic cable for conencting freeview if it has an output. Also whilst at it get better one to replace the freebie that comes with set.
    I got mine, Cable Talk ones, from ebay at a tenner each which was much cheaper than normal. Try some of the shops on there or just do a search.
  3. Samwise
    Samwise
    Thank you, will look at getting those. As I do want to upgrade all my connections. :smashin:
