denon dht550 sd
Discussion in 'Home Cinema Buying & Building' started by tc114, Nov 12, 2004.
  1. tc114
    tc114
    Oct 7, 2004
    17
    3
    :) Hi there,
    i'm looking at getting the dht-550sd denon home cinema system. i've read that you can get this player modified to multiregion using a disc to update the firmware. I've seen links to it but cannot find it.
    i could buy from avland (£640) but cheaper at unbeatable(£580) however not multiregion.
    Any ideas where i can find/get the disc/modification?
    many thanks in advance
  2. newcomer
    newcomer
    :lesson: For the extra £60 i would buy it already multi region??
  3. TheDevil2004
    TheDevil2004
    Nov 18, 2004
    71
    I just got the Denon aswell, £420, without speakers, I was told that it can be converted to multi region by CD aswell, if you do find out how to do this let me know.
  4. kuma
    kuma
    i know the denon dht500 can be made multiregion using a firmware upgrade, its available from these forums if you search for it
  5. bchohan
    bchohan
    I purchased the Denon DHT-500 and have been looking for the multi region firmware without any luck. Would greatly appreciate if anyone would be able to guide me in the right direction.
  6. Nippy_Kangaroo
    Nippy_Kangaroo
    you can buy the denon dht550 from qed.co.uk for £550
  7. Links
    Links
    Dec 12, 2002
    108
    +5
    Can anyone find any rear view pictures of this system? I've tried everywhere to no avail.
    Also I see it has two component inputs. I'm assuming that one of them has to be for the DVD part of the system. I've got a PW6 with a component board. However I also want my Xbox and PS2 component leads to be connected also.
    Any ideas?
