denon dht50sd problem
Discussion in 'Home Cinema Buying & Building' started by rdbushell, Jan 18, 2005.
  1. rdbushell
    rdbushell
    Jul 29, 2004
    25
    Hi, I’ve had my dht500sd since sept, and problems have started arising with dvd playback. When playing some dvds, the player pauses the dvd for about 4 secs, then it restarts, when this happens the player tries to change the audio input from either dolby digital or dts to analog, then when it restarts its back on the original setting. This is a major problem as on some discs (i.e lord of the rings, return of the king) it happens about 6 times.
    any body else experienced this?
  2. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    No and I hope I don't. Have you been in touch with whoever sold you the unit?
