Denon Dht500st
Discussion in 'Blu-ray & DVD Players & Recorders' started by rammy, May 4, 2005.
  1. rammy
    rammy
    Hi I Just Bought Myself A Denon 500st Very Impressed With It, The Only Problem Is A Few Of My Dvd's When Playing Are Out Of Sync. E.g. Lipsync Iv'e Even Measured How Far Away I Sit From The Speakers And Tv But Still No Joy. Iv'e Tried Numerous Of Settings In The Delay Set Up Menu But I Cannot Get It Right,also What Sound Is Best To Use For Music Cd's? Any Suggestion Will Be Appreciated Thanks
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Are you using progressive scan? What type of television do you have? It sounds like video delay being caused by slow progressive scan processing, which to honest is to be expected on a unit such as the Denon DHT5000ST where therre are inevitable compromises on the quality of components used due to the price.
  3. rammy
    rammy
    Hi I'm Not Sure About The Progressive Scan I Think Its Turned On. I'll Check, I Have A New 46"samsung Dlp Tv,some Films Are Fine But I Have Sapranos On Dvd But It's Really Putting Me Off With The Lipsync Being Like It Is.thanks
