Denon DHT500SD speaker wall brackets
Discussion in 'Home Cinema Buying & Building' started by David McW, Mar 3, 2005.
  1. David McW
    David McW
    I just recieved my shiny new denon from QED today and think its awesome but im having real difficulty finding wall brackets for the speakers due to them not having mounting holes on the rear of the speaker.
    This is my first home cinema kit so yes i am a newb and any advice would be welcome like where i can buy brackets to wall mount the speakers.
    THANKS
    Davidhttp://www.avforums.com/forums/newthread.php?do=newthread&f=114#
    please
  2. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    Hi David,
    Congratulations on your new purchase - I'm sure it'll bring you hours of pleasure and the neighbours hours of stress! :smashin:
    Many people (inc. myself) have used these AVF brackets and they do the job just fine. Can be picked up at Currys for about £15 a pair. Someone once mentioned B&Q do them too, but I can't confirm that.
    I'm not sure there's anything else out there that works well with the Denon? Anyone else have any different suggestions???
    Hope that helps :)
    Jud
  3. David McW
    David McW
    Thanks for the link do these actually attach to the base of the speaker ?
    I saw them in the local currys but was unsure they were compatible
    thanks
    David
  4. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    They certainly do. They come with two bars - long & short. I used the long ones. I posted a pic on another thread here http://www.avforums.com/forums/showthread.php?t=190507&highlight=avf but if you do a search, I'm sure you'll find some close-up pics too.
    Jud
  5. David McW
    David McW
    Thanks for that i just won a multiregion firmware upgrade cd on ebay for 99p so with my brackets that should be my system sorted.
    Thank you Jud
    David
  6. Strangerer
    Strangerer
    Watch out with the firmware upgrade. There's a thread on here somewhere saying how the one they tried ballsed up their player beyond repair. :eek:
