denon dht500sd setup problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by sjohns28, Jan 14, 2005.
  1. sjohns28
    sjohns28
    I'm looking for a little advice please,
    I've just recieved the denon dht500sd home cinema,which uses the adv500sd dvd player.
    it is playing dvd pict and sound fine, but i cannot seem to get sound through the 'Audio in' i.e. if I plug in an external source like the t.v. I do not get sound. I have also plugged a playstation in via 2 phono and video lead but only get picture, not sound.
    It has to audio in sections so I presume these act just like a line in
    Any suggestions? or is it broken.
  2. gphys
    gphys
    did you ever sort out your problem, I want to do the same ie play sky back through the denon and was goin to do just what you have described
  3. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    What you need to do when you have video 1 or 2 selected and you are using analogue leads on the 500 remote, above the slide switches is a button marked "input mode" press this till you select analogue. You should get your sound.
