Denon DHT500SD setup problem
Discussion in 'Home Cinema Buying & Building' started by fishter, Apr 16, 2005.
  1. fishter
    fishter
    Hi All,
    Just unpacked my Denon DHT500SD and got it all plugged in.
    I'd really like to be able to program the remote to change channel on the TV. Does anyone have a more comprehensive list of codes than the one in the manual?
    I've got an LG TV, but they simply aren't listed in tha manual.
    Graeme Hilton
    Owning a DHT500SD and a DM31, now going in the bedroom.
  2. Conn
    Conn
    Jan 2, 2005
    2,074
    +170
    Not got my manual to hand - is there a listing for Goldstar? (LG is short for Lucky Goldstar). Failing that email to Denon - there is a link from the website that gets answered fairly quickly
  3. fishter
    fishter
    Thanks Conn.
    One of the codes for Goldstar had an effect, but unfortunately the keys don't do what they're supposed to. I'll try Denon to see if they've got any further ideas.
