Denon Dht500sd Problem! Help!
Discussion in 'Home Cinema Buying & Building' started by rdbushell, Sep 11, 2004.
  1. rdbushell
    rdbushell
    Jul 29, 2004
    24
    Just recieved my denon dht500sd, it worked fine the first day, then the following day the remote started playing up. It activates itself, and the sound input button is always on, sometimes flashing randomly, and changing the sound from dts, to auto, to dolby etc! if i remove the batteries for about half hour the remote will work for a bit then start doing it again. In have a muti-region player, and was wondering if the hanset was used to programe it? and caused the problem? and if there is a way of reseting the remote to default? or do i just need a new remote?
    thanks
  2. bobbypunk
    bobbypunk
    denon machines are normally upgraded using a firmware upgrade on a disc, so I would suspect it was just a faulty remote!
