Denon DHT500SD - Can it cope with DVD-R's?
Discussion in 'Home Cinema Buying & Building' started by dougbryson, Aug 25, 2004.
  1. dougbryson
    dougbryson
    Hi folks,
    I'm on the verge of buying the Denon DHT500SD system and wondered if anyone can confirm that it will play DVD-R's or +R's?
    Thanks!
    Doug
  2. tedge
    tedge
    Yes, I just burnt 2GB of mp3s to a DVD+R, plays very well. You can navigate directories too with the on-screen display.
    Unfortunately my DHT500 is region 2 only, I assumed they were all multi-region but this one from Unbeatable isn't :(
  3. dougbryson
    dougbryson
    Thanks for the reply - I have another quick question - does the DHT500 have the 2mb buffer memory that other Denon DVD players have to make layer changes imperceptible?
  4. tedge
    tedge
    Don't know about that, i've only played a few DVDs but didn't notice the layer change.
