Denon DHT500 SD Multiregion?
Discussion in 'Home Cinema Buying & Building' started by sofasurfer, Nov 11, 2004.
  1. sofasurfer
    sofasurfer
    Dec 16, 2003
    1,521
    63
    +117
    Hi there,first post but can anyone help me out?
    Ihave read that you can make the Denon DHT 500 SD multiregion via a download.
    Where can I get it from?
    Help much apreciated :)
  2. neil20v
    neil20v
    Hi mate you definately can make it multi region.....I bought one already converted from www.superfi.co.uk
    Regards
    neil
  3. telcom1
    telcom1
  4. bchohan
    bchohan
    Hello
    I went to the link provided by telcom1 but still not able to get firmware for DHT 500 to make it multi region. If anyone knows where I can get the image of the CD that would be greatly appreciated.
  5. SkyJawa
    SkyJawa
    Sep 26, 2004
    193
    +3
  6. chiily
    chiily
    Oct 17, 2003
    25
    3
    Just to confirm, flashed my Denon 500SD last night, now multi region, the firmware works :)
    Thanks.
  7. mekonj
    mekonj
    Feb 26, 2005
    153
    Reading
    +4
    Does anyone know where I can get a similar multiregion upgrade (one I can download and flash the player myself) for the Denon DHT550SD?
    Just trying to save a few squids when I finally get round to buying it!!
  8. zero_cool
    zero_cool
    Sep 7, 2005
    83
    Hey,
    I was just looking at this site. Where it says:
    Then burn the firmware file to disk with a dummy file called AADUMMY.XXX
    What exactly does it mean. Just take any old file off of your comp that is more than 40MB, rename it to AADUMMY.XXX and then burn it to the disc with the firmware?
  9. caltune
    caltune
    Thats what i did last week and managed to muck the system up!!! I downloaded the file and burnt it together with a file of about 40mb, burnt it put in the denon the screen went black it then said 'erase' with a load bar then 'write' with a load bar then finished. I ejected the disk turned it off tuned it back on again there was some clicking and then it came up 'mecca err' :oops: I rang denon they said do a factory reset which is back skip, stop then hold back skip for seven sec's all on the dvd unit, i did that and it still came up mecca err. So now the shop that i bought it off is picking it up on tuesday so i will keep you posted.
  10. zero_cool
    zero_cool
    Sep 7, 2005
    83
    Hmmmm......Might leave that one then!
  11. jcamp1
    jcamp1
    Nov 9, 2005
    York
    I still don't understand that instruction on http://www.leedsdig.plus.com/.
    The second file just follows a link to some text. What exactly do I burn to CD. The first file and a dummy file I understand but what about this checksum thingy??!
    (FIRST POST!!!!!!!!!!!! :thumbsup: )
  12. stuart27
    stuart27
    Just tried to download the multi-region fix for the 500sd and forgot to follow the full instructions about leaving the DVD drawer open when switching off / on.
    Problem now is when I switch on, the dvd drawer won't open and I get a mech error message.
    Any ideas if this is fixable....or have I just blown £400???
    hope someone can help out an old fool!
  13. mairclan
    mairclan
    Sep 20, 2007
    Just bumping this as it is exactly what I am after but the link supplied no longer seems to work...
