Denon DHT500 problem
Discussion in 'Home Cinema Buying & Building' started by sofasurfer, Mar 15, 2005.
  1. sofasurfer
    sofasurfer
    Dec 16, 2003
    1,544
    63
    +127
    I have not used my system for some time and toay when I switched it on it displays a 'PROTECT' message on the machine and then switches off.
    Anyone got any ideas how to sort it out?
    Many thanks
  2. nathanhill69
    nathanhill69
    Oct 5, 2004
    392
    +19
    Check all your speaker cables, make sure that none of the bare wires are touching one another as this may cause a short.
    Nathan
  3. sofasurfer
    sofasurfer
    Dec 16, 2003
    1,544
    63
    +127
    Did all that.Unhooked all the cables and only left the power in.Still got the same error message.
    Had to take it to my local dealer to send it back to Denon for them to have a look at it :thumbsdow
  4. kismet110
    kismet110
    Feb 6, 2005
    2,364
    London, UK
    +389
    I'm pretty sure this has come up in another thread on here in the past, not sure what the problem/resolution was but if you've now sent it away then fingeers crossed...
    ALI
  5. Conn
    Conn
    Jan 2, 2005
    2,075
    +170
    It has - I seem to recall it was the speaker problem Nathan mentioned. Chances are the same message covers different problems.
  6. dukegonz
    dukegonz
    I'm currently installing a crestron networks and i need DHT 500SD modules for crestron. I tried the web and cant find it. Please anyone help me. THANKS
  7. mekonj
    mekonj
    Feb 26, 2005
    153
    Reading
    +4
    I'm looking for a non-working DHT500sd for a little project for my xbox media centre. If you don't manage to fix it, let me know and I'll be happy to pay you a small amount for the unit. If its still available, post in the 'for sale/wanted' thread and PM me.
    mekon
  8. kismet110
    kismet110
    Feb 6, 2005
    2,364
    London, UK
    +389
    mekonj
    I think your post is aimed at the OP but coincidentally I have a faulty Denon 500SD at the moment, gets MECHA ERROR on the DVD drive and DSP ERROR for the sound. A company wants £300 to fix both things (£180 for the DPS only) so decided to get a Yamaha AV61 package as that's nearly £100 cheaper than getting it repaired :eek:
    PM me and maybe we can work something out for it?
