DENON DHT-550SD OR (AVR-2105 & SYS-550SD SPEAKERS)
Discussion in 'Home Cinema Buying & Building' started by micramda, Jun 20, 2005.
  1. micramda
    micramda
    Jun 16, 2005
    +7
    I have a bit of a predicament! I originally wanted to buy the Denon DHT-550SD but then realised I could get a receiver and the same set of speakers used on the all-in-one. Apart from that I don't need another DVD player. So I thought I'd go for the Denon AVR-2105 receiver and SYS-550SD speakers.
    The question I want to ask is:
    Will the sound for movies be better on the Separate receiver and speakers or on the All-in-one?
    I hope the answer is the separate receiver sounds better.
    Can anyone clarify this?
  2. Conn
    Conn
    Jan 2, 2005
    2,074
    +170
    Better? I very much doubt you would find any significant difference
