Denon DHT 500SD
Discussion in 'Home Cinema Buying & Building' started by meadow man, Jan 26, 2005.
  1. meadow man
    meadow man
    As a complete novice, I recently installed and set up a Denon DHT 500SD all in one. When playing a video, the sound does not come through the surround speakers, only the TV speakers. Can anybody suggest a solution? Everything else works perfectly. Could there be a setting I have missed? I'm concerned that there is a fault with the unit.
    Regards
  2. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    There are two methods of connection.
    You can simply select tv on the 500 and it should draw the sound down from the tv. For some reason this doesn't work on my set up.
    Instead I have phono cables from the tv running to the Denon's Video 1 input, this supplies sound from anything connected to the tv.
  3. zmoosa1
    zmoosa1
    Jan 18, 2005
    886
    Loonsville
    +58
    meadow man - Try using the function button on the remote until 'TV' is diplayed on the receiver. I have my Denon connected via Scart and this does draw the sound from the TV, no phono cables needed.
    Regards
  4. meadow man
    meadow man
    I do have the 'TV' mode selected when playing back the video, but no sound through the amp/surround sound. The sound works perfectly on DVD and TV, only when playing a video. I only get sound through the TV. Strange!
    Regards,
  5. nathanhill69
    nathanhill69
    Oct 5, 2004
    392
    +19
    Can you not connect the video using phono leads between the Denon and the VCR and if this is how you have got it arranged have you selected analogue as that fuctions input on the Denon?
    These are just possibilities off the top of my head.
    Nathan
  6. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    Do you have the vcr connected to the tv via a scart cable?
  7. meadow man
    meadow man
    zmooza1.....I could try that.
    Regards,
  8. meadow man
    meadow man
    We tried audio input into VCR1 and VCR2 from both the TV and VCR audio outputs via phono cables, with no audio output from the Denon (selecting VCR1 and 2 respectfully). The Denon only accepts audio in via a scart, which is connected straight into the TV stcart. I know I said I was a novice, but I have help here from our telecomms guru "McTroozers" who helped try and set it up. The feeling is that the Denon may be faulty, unless there is an unknown set up procedure we have missed.
  9. nathanhill69
    nathanhill69
    Oct 5, 2004
    392
    +19
    When you had the VCR connected via the phono lead into Video 1 or 2 you did also select "analogue" as the input on the relevant Denon function? Also, have you got any other source you could test like a Sky Digibox or games console or another VCR?
    I'm sorry that I'm repeating myself but I understand how irritating these things are and sometimes it can be the most simple things, a faulty Denon, faulty leads or faulty VCR.
    Good luck
  10. meadow man
    meadow man
    nathanhill69........We tried the "audio out" from the TV. Can this be considered another source? Also, how do you check or set the analogue function on any of the Denon inputs?
    Regards,
  11. nathanhill69
    nathanhill69
    Oct 5, 2004
    392
    +19
    Firstly, apologies if I'm going over something you understand but it's all in the name of trying to help.
    On each function, Video 1, Video 2, DVD, TV etc. you are able to select (to a greater or lesser degree) the type of Input that it is receiving (look on the remote control for the "Input mode" button). Say for example you have plugged the VHS phono outs into Video 1 on the Denon, select the Video 1 Function on the Denon, now on the remote press the "Input Mode" button to select ANALOGUE as that's the type of signal your VHS is sending to the Denon. If it was set to DIGITAL then you're Denon won't play back the VHS audio.
    Bit of a rubbish explanation but when you check out the remote it will all become clear.
  12. meadow man
    meadow man
    nathanhill69......I don't understand, believe me!! A work colleague helped me set it up. He knows a bit about it, but were stumped with this one. I will try your option first opportunity -I'm away from home right now, but look forward to getting back to give it a go.
    Thanks,
  13. meadow man
    meadow man
    nathanhill69......I don't understand, believe me!! A work colleague helped me set it up. He knows a bit about it, but we were kinda stumped with this one. I will try your option first opportunity. I'm away from home right now, but look forward to getting back to give it a go.
    Thanks,
  14. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    On the remote above the slide switchs, make sure both are to the left, press the input mode button to change to analogue.
  15. Radg
    Radg
    Jan 28, 2005
    34
    I am new as well to this game but is there not an issue if you dont have a fully wired scart then you might not get sound in one direction?
  16. meadow man
    meadow man
    Thanks to everybody for your help. I managed to suss it out using the remote using the input button!
    Cheers.
  17. meadow man
    meadow man
    Thanks to everybody for your help. I sussed it out on the remote by fiddling with the input button right enough!
    Cheers.
