DENON DHT-500SD Wall Brackets
Discussion in 'Home Cinema Buying & Building' started by dino25, Jun 20, 2005.
  1. dino25
    dino25
    Hi 2nd Post regarding this system and wondered if anyone has got there surround sound speakers on the wall instead of floor stands?? I have bought a set of AVF 461170 brackets which were recommended by Denon and they are rubbish. Has anyone used anything else??? Please Help!!!!
  2. nathanhill69
    nathanhill69
    Oct 5, 2004
    392
    +19
    I've got these and they do the job very well, also designer partner seems to think they're suitable un-obtrusive:
    http://www.avf.co.uk/product.php?cat=HF&product=P6199
    If you do a search through this forums there are quite a few threads addressing speaker mounting/brackets for the Denon , also I posted some pics of the speakers in situ as a favour for someone, have a hunt and you'll find them.
    Nathan
  3. justinh
    justinh
    May 6, 2002
    113
    Slough
    +6
    I was told by a helpful guy at hifistore that these are the only ones he knows and sells that fit the screw in fittings on the Denon DHT-500SD speakers (not the centre speaker though).
    http://www.hifistore.co.uk/product.php?qsProd=TSL11
    He also selss the Denon system so should know.
    I have purchased them and they look ok but have yet to fit the speakers.
  4. THE GFP
    THE GFP
    Jul 9, 2006
    888
    Godmanchester, Cambs
    +22
    wow found this 3 year old thread
    ive got this system and am about to sell it as i cant find wall mounts for the 4 speakers
    anyone got any newer links that work as its a lovly system just the speakers are bad on the floor
  5. salsa-king
    salsa-king
    Feb 19, 2005
    437
    22
    Nottm
    +17
