Hi all,
Is there an alternative to the Denon SS-30 speaker stand for the DHT system? Ive looked at the Alphason range and they all have the rear mounting as opposed to the 2 threaded holes that Denon use. Is there another brand to look at?
Ive tried without luck to order the SS-30s but they along with much of the Denon range are out of stock indefinately.
As far as speaker cables go, what is the largest diameter which will fit into the spring clips on the DHT - I was initially suprised it doesnt come with posts and have a feeling my thicker cables wont fit.
Can someone clear up the question of RGB and Scart leads please, Im being a bit thick! I only have one RGB Scart on the TV so is my best option to get an RGB only scart cable from Denon-TV ? Or is it possible to get an RGB (Component) to Scart cable and would there be any difference?
All I have to connect to the Denon is a Sky Digibox (Not +). Im not really sure how to connect the Sky to the Denon. Is this done from Sky-TV and then back to Denon? I appreciate I wont get full 5.1 from the Sky box.
Will I have to change the input from Sky to the DVD or is this done automatically?
Lots of questions, but thanks in advance for any thoughts
Rgds
Rich
Rgds
Rich
