Denon DCD-1500AE or DCD-700AE+PMA700AE
Discussion in 'Hi-Fi Stereo Systems & Separates' started by jasonuk, Apr 25, 2007.
  1. jasonuk
    jasonuk
    Dec 26, 2004
    152
    16
    Need some newbie advice.
    Given I already own the Denon AVR-3806 AV Receiver.
    Will I get better sound if I just get the better Denon DCD-1500AE? or will I get better sound by opting for the cheaper DCD-700AE+PMA-700AE Amp.
    Cost will be around £400 for either option.
    Any guidance would be most appreciated.
  2. Helicon
    Helicon
    Apr 4, 2005
    5,016
    +261
    The DCD1500ae will certainly sound better than most DVD players, but it will be held back a little by your amplifier. If music is very important to you, go for a seperate hi-fi system. You could add the DCD1500 to what you have and buy the PMA 1500 at a later date and give yourself a better hi-fi system in the longer term. Also this will give you a wider choice of quality speakers to choose from.
