Denon DBP-2012UD ??
Discussion in 'Blu-ray & DVD Players & Recorders' started by Martyn35, Jan 10, 2012.
  1. Martyn35
    Martyn35
    Jun 29, 2008
    248
    bedford
    +7
    Hi all
    I`ve been looking at buying one of these, as i`m also looking to go 3d but as i`m quite limited on space & plugs i`d also be using it as my cd player currently a marantz 6003.
    Would the denon be as good or better as the marantz as a CD player ?
    Cheers Martyn
  2. Hepps
    Hepps
    Oct 3, 2011
    150
    +17
    I have both and whilst I have not done a back to back I reckon the 2012 would be better or at least not sound noticeably worse.
    But read other threads for pros and cons on the 2012. Mine broke which has left feeling pretty negative about it. It is also VERY slow to load discs or respond to any commands. If that bothers you when popping a disc in to listen/watch then look elsewhere.
    Hepps
