macer18
I have a Denon CEOL N9 and it used to work perfectly. Since a couple of weeks the internet radio stream looses the network connection as soon as I switch on / wake up one of my Android devices, which run in the same network. The Denon is conneted via wire to a Nighthawk R7000 Wifi router. I can rule out the router (same issue with other router) and the connection type (same issue over wifi). Also, I do not have any Danon related apps installed on my Android devices.
Any ideas what the problem could be? The connection restores itself after 1-2min but this issue is super annoying. Thanks.
