Question Denon AVRX2400H Atmos speakers setup
Discussion in 'AV Receivers & Amplifiers' started by The raven, Aug 21, 2018.
  1. The raven
    The raven
    Jul 2, 2018
    19
    Thanet
    +5
    Hi all im very new to the field of AV
    So i am about to install 2 ceiling atmos speakers rated at 8 Ohms,
    Now this is where i am confused the amp says 4-to 16 ohms.
    So does a that mean i can wire a 2nd set into the av and change the settings to allow for 4 ceiling speakers?
    Or have i got it totally wrong?
  2. simonlewis
    simonlewis
    Jul 31, 2014
    4,704
    stockport
    +1,757
    I think you have got it totally wrong, just two ceiling speakers should do the job.
  3. Dolus
    Dolus
    Apr 26, 2005
    600
    46
    Gosport
    +186
    4-to 16 ohms means you can use speakers that have an impedance of between 4 and 16 Ohms and has nothing to do with the number of speakers.
  4. The raven
    The raven
    Jul 2, 2018
    19
    Thanet
    +5
    Aw ok I figured I could put two sets in 8 plus 8 would be 16 and that would work.
    Thanks for the heads up I’m learning as I go
