So my Denon receiver (AVRX2400) has had its HDMI board replaced by Denon which fixed the defective "HDMI Input 3" issue I previously posted about. HOWEVER the other problem I was having (blue noise often being inserted into the image) remains. I've finally filmed it happening and uploaded a video to youtube - any suggestions as to what might be causing this and how can I get it fixed?
Here's the link:
As you can see, the Denon receiver intermittently adds "blue noise" to the image sent to the TV. This happens about 1/3rd of the time. It happens on all inputs and is not an HDMI cable/satellite box/TV issue (the same set up works perfectly with no blue image noise being added if you remove the Denon receiver from the pathway and simply plug the satellite box directly into the TV with the same cables or if you replace the Denon receiver with a different HDMI switch box). Sometimes the TV also displays an "invalid format" error message but this is infrequent and I haven't caught it on video yet.
I've used the Denon receiver's built in trouble shooting feature to reduce the maximum image quality to 1080p maximum (since the HDMI cables aren't 4k compliant and I don't use any 4k hardware anyway) and I've turned off the ancillary features like HDR etc again using the Denon. I've also used the Denon receiver to test the cables (and they were tested good on 1080p but failed 4k, which is fine since I don't use 4k anyway).
The really annoying thing is, I can (as demonstrated on the video) temporarily fix the issue by unplugging and reinserting the HDMI cable between the Denon and the TV and then it works for a period (sometimes a few minutes, sometimes a few days).
Turning everything off and on repeatedly also sometimes works but is much less predictable.
This is becoming really annoying and I'm on the verge on insisting on a replacement receiver, but I'd prefer to avoid doing this if it's at all possible. So you guys are my last chance! Any tips / suggestions / ideas??
Thanks!!
Here's the link:
Thanks!!
