Denon AVR3805 more remote codes?
Discussion in 'AV Receivers & Amplifiers' started by ghosty, Sep 23, 2004.
Tags:
  1. ghosty
    ghosty
    Feb 1, 2004
    16
    Does anyone know if there are any more codes for the 'smart' remote control (rc-970) that comes with the 3805?
    in particular i want to use the remote to control my arcam dvd player, but there doesnt seem to be any codes for arcam under the dvd section. can anyone help?
    thanks,
    g
  2. michael.redfern
    michael.redfern
    Oct 14, 2003
    864
    Manchester
    +92
    It is a learning remote is it not? Can you not just get it to learn your Arcam remote codes by pointing it at the Denon remote like the Remote Angel does?
  3. ghosty
    ghosty
    Feb 1, 2004
    16
    yeah ok, i was being lazy and seeing if there was an easier way before i did that. i also couldnt find any codes for my pioneer freeview box, so it has alot of learning to be done! ;)
    thanks!
