Denon AVR3802 speaker bindings
Discussion in 'AV Receivers & Amplifiers' started by Mike72UK, Jan 14, 2002.
Tags:
  1. Mike72UK
    Mike72UK
    Could someone advise me how I remove the black plastic caps inside the speaker binding before inserting banana plugs, or is there some litle trick that I am amissing
    Thanx
  2. Noman
    Noman
    Thin sharp object (like a pocket knife) Get it in (from the "side"), wiggle and it will either pop out or you will be able to get it out with your nails
  3. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    Get a 3 inch chisel and a Big Old Lump HAMMER and bash the buggers clean out............That'll do it!!?!??!
  4. mjn
    mjn
    May 24, 2001
    22,720
    Herts, England
    +10,860
    the bigger the hammer, the easier they come out!!
  5. greeny
    greeny
    Must say I'm very dissapointed with the 3802 speaker bindings, they are cheap, not very robust, too closly spaced, not gold plated etc, etc.
  6. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    +77
    and they don't even supply a chisel set in the box..........;)
  7. Mike72UK
    Mike72UK
    Thanks chaps.......managed to pry them out....although I had to go down to the hardware store and purchase a chisel and sledgehammer as they were the two items lacking from my toolbox.....very happy with the 3802....connected up two pokey old yamaha hi-fi speakers whilst I await delivery of new a\v speaker package and even they sounded better !
  8. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    +77
    It's a cracking amp.......Enjoy! :D
