Denon AVR3300
Discussion in 'AV Receivers & Amplifiers' started by Paden, Oct 8, 2001.
Tags:
  1. Paden
    Paden
    Jul 27, 2000
    578
    +23
    Hello all!
    Just found out that my volume knob on my receiver doesn't work, although I can adjust it fine from the r/c. Anyone had the same trouble or have any suggestions?
    Many thanks, Paul.
  2. Paden
    Paden
    Jul 27, 2000
    578
    +23
    Cheers Mark
    I think it might just still be under garuntee but I'm not keen on sending it away for repair for such a minor fault (probably come back with more!). I can live with the problem I just wondered if anyone had had the same trouble & if there was an easy fix.
    Thanks again!
  3. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Nightmare
    Me A1SE knob works ok, although I very rarely use it!
    Is your unit too old to be fixed under warranty?
    Mark
