Denon AVR2805 or Yamaha RX657RDS?
Discussion in 'AV Receivers & Amplifiers' started by bogie, Jul 21, 2005.
Tags:
  1. bogie
    bogie
    Jul 21, 2005
    72
    Just got my Sagem D45 and Pioneer 530, now looking to get the right amp.
    I was originaly swayed to the Denon but now the Yamaha looks like tempting.
    The Yamaha can be bought for less but that doesn't really come in to it.
    I will most likely be hooking it up to AE Aego 5.1 or 7.1 system (not decided wich one of those either yet).
    I want to feed all video via the amp and output via component only to my D45.
    Any help greatly appreciated.
    Bogie
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    The 2805 is a bit better than the 657 if all the reviews are right, but demo is always the best advise if you can.
  3. skinnyfat
    skinnyfat
    If the yamaha is looking tempting then why don't you consider the RXV 1500 which I believe can be had for a good price now if you shop around. But as always try and demo first
    Skinny
