Denon AVR2801 or Sony STR-DB830
Discussion in 'AV Receivers & Amplifiers' started by Tracey, Mar 21, 2001.
Tags:
  1. Tracey
    Tracey
    I'm thinking of upgrading my receiver, my question is, would the Denon AVR2801 be a significant improvement on a Sony STR-DB830, bearing in mind I am using Arcam amps to power the front and centre speakers so the Denon would only be used purely as a processor and to power the rear speakers.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Not really worth it just for the processing and rear amping. You may as well get the 3801.
    Rick
    'I am just a figment of your imagination.'
    Work Site: The Sound Gallery
    Home Site: WD A.V.
  3. Tracey
    Tracey
    Hi Rick,
    thanks for the reply, so are you saying that the 3801 WOULD be a significant improvement or would I really need to go for a separate processor which would cost twice as much because I would then also need to buy an amp to power the rear speakers.
    Tracey :rolleyes:
