Denon Avr2307 Or Sony Da1200es
Discussion in 'AV Receivers & Amplifiers' started by PHSSLL13, Dec 28, 2006.
Tags:
  1. PHSSLL13
    PHSSLL13
    Dec 9, 2006
    108
    Manchester
    :hiya:
    This is going to be my first venture into the home av seperates route and i have been reading the forums and mags etc and i have narrowed it down to these 2 amps
    DENON AVR2307 (£450)
    SONY DA1200ES (£400)
    which one would u guys go for and why it will be hooked up to
    KHT2005.2 OR CANTON CD1 SPEAKERS
    DENON1930 OR OPPO981 PLAYER
    MANY THANKS PAUL
  2. LeeCo
    LeeCo
    Apr 10, 2007
    90
    I am in the exact same boat and have also narrowed it down to these two so would love to hear some opinions.
    You can get the Sony for £330 online compared to about £460 for the Denon, but from what Ive read the Denon is future proofed re DTS HD etc and also has Ipod control
  3. sp_harris
    sp_harris
    Feb 13, 2006
    582
    +60
    If it helps I went for the 2307. I ruled out the Sony 1200 due to lack of up-conversion of signals (which was important to me). i.e. I can have 2 hdmi inputs and some component inputs and still only need 1 hdmi cable from amp to plasma. whereas the Sony would have needed both hdmi and component from amp to plasma. I guess you have to decide if this feature is important to you.
    Also my understanding was that the Sony 1200 couldn't handle the new sound formats over hdmi, so if I get a PS3 in the future the Sony 1200 would only have allowed me to get dobly digitial over optical, whereas the Denon will allow me to get LCPM PCM (something like that) over the hdmi cable.
  4. sideysid
    sideysid
    Jan 2, 2005
    471
    +31
    You can still make use of the next gen audio (Dolby TrueHD etc) with the 1200es, you just have to link up the analogues as optical doesn't have the bandwith.
  5. LeeCo
    LeeCo
    Apr 10, 2007
    90
    This has confused me now, although good to know!
    I had almost resigned myself to getting the Denon even though the SONY is loads cheaper, primarily due to the DTS HD factor as I was told the SONY wasnt future proof re HD sound.
    If you connect systems to the SONY via the method you suggest will you really get no loss in quality and get the full HD sound?
  6. sp_harris
    sp_harris
    Feb 13, 2006
    582
    +60
    Presumably you mean wiring up the 6 individual inputs from source to amp - I guess this is only possible from 'proper' HD-DVD/Blu-Ray player, don't think PS3/X-Box 360 have these outputs
  7. hungry_hog
    hungry_hog
    Apr 13, 2007
    when people say the the avr2307 is "ipod compatible":
    - have a version of the ipod click wheel on the remote?
    - does it display the ipod screen / menus on the tv?
  8. pils
    pils
    Jan 11, 2007
    104
    +5
    1. Uh, it has a directional pad and a select button if that's what you mean.
    2. It will show the contents of the iPod, playlists, albums, etc. in glorious white on grey text only. It isn't very pretty, but it works.
    This is of course assuming you get the Denon ASD-1R dock:
    http://blog.denon.com/asd-1r/
  9. VDG
    VDG
    Jun 10, 2006
    204
    +8
    Paul, Sony 3200 would be a direct competition to Donon 2307 (as Sony 1200 doesn't support LPCM [HD sound through HDMI] processing, only pass through).. for what it worth Oppo 981 and str-da3200 works here like a charm.. AFAIK Oppo/Denon have some HDMI issues although I never experienced it (had a chance to play with it for a couple of weeks)
  10. sk8
    sk8
    Sep 19, 2006
    556
    B&NES
    +17
    2307, 1930 and Kef 2005 are a great combination :thumbsup:
  11. Alan V
    Alan V
    Jul 6, 2008
    Hi Guys
    I have a sony-da1200es, 7.1. I was using my Alpha 8a amp and Kef speakers untill the Alpha lost a channel! I am tempted to us the Sony for my CDs but wondered if the spec on the Sony is upto quality?
    Thanks Alan V
