Question Denon AVR2113 - No Power
eximo
Hi all
im looking for some pointers. We just had a power cut which has seemingly taken out my Denin AVR2113. Currently sitting plugged in but no power and the LED Is completely off.
ive checked the cable and tried another kettle lead but nothing. I’ve also had a quick look inside and the two fuses inside next to the power socket are ok.
so what else could I look at?
i don’t have the funds for a replacement right now so keen to see if I can get it started.
Edit: So i disconnected all wires and then it seems to work. Reconnected everything and no problems. Thanks All
wiz
Unplug for 10 mins, then try a factory reset
dobrykamil
If the power LED is off, you need to take a look at the standby power supply.There is another, small fuse on that pcb board and it might look like this:
