Denon AVR2105 - Help with Recording
Discussion in 'AV Receivers & Amplifiers' started by eterrier, Aug 13, 2005.
Tags:
  1. eterrier
    eterrier
    Can anybody help a beginner?
    I have a Denon AVR2105, and want to be able to use it to recored from an input source on TV/DBS channel to a DVD Recorder connected (In + Out) to the VCR-1 channel.
    If I set my REC out selector to TV/DBS, should that be it? Does the receiver default to sending the REC out signal to VCR-1?.....or can you influence whether it goes out to VCR-1 or VCR-2 ? (I did wonder if the video select was related to this, but I now don't think it is.)
    I've then set my input source to VCR-1, and although I can hear the TV/DBS Signal, I cannot see it on the TV. Everything is connected via S-Video, and I've defiinitely got the S-Video to SCART lead into the right S-Video enabled SCART input on the TV, because other S-Video Signals make it to the TV OK, just not through the REC-Out.
    Any ideas?
    Andy, Huddersfield.
