Denon AVR1905 Vs Yamaha RXV450 Whats the best one
Discussion in 'AV Receivers & Amplifiers' started by timmy22, Jan 1, 2005.
Tags:
  1. timmy22
    timmy22
    Mar 13, 2004
    10
    Thinking of buying the Denon AVR1905 or Yamaha RXV450 just really for films,music not important.I am going to use my eltax nova speakers for now with the amp.Will i need a new sub as it just has the same two wires as the rest of the speakers or is there a way to use it.
    http://www.eltax.com/products/salgelektronik.php?varenr=11027
    (speakers specs)
  2. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
    timmy22,
    Not sure regarding the eltx nova speakers and the wires, but I do know that there should be a few owners of eltax speaker packages, hopefully they will notice this thread when I push it to the front again. You could also try ask in the speakers section.
    Regarding the amp, both are excellent choices. But guessing that your budget is up to £230? I probably would recommend you look at the Pioneer VSX-D814 for £220 from www.Petertyson.co.uk or www.prcdirect.co.uk .
    Very dynamic, powerful, controlled and feature rich amp with the added bonus of automatic room calibration (basic system that with help of a microphone adjusts the delay times, speaker size, speaker volume etc) which is very practical indeed.
    Wasabi
  3. SpudGunMan
    SpudGunMan
    the D is slightly underpowered to what your lookign at. To get a bad ass unit i woudl reccomend a 2+ line of the denon. as last posted check out other cheaper brands that will get you more "bang for the buck" when it comes to sheer uhmph since your prolly not audiophile'n it but just want a "bad ass movie sound" with a different amp you will get more power output
    or just spend a few mroe and get the next Denon up.
    however for the kids reading at home the 1905 is a VERY good amp if you are thinking of buying it. (i personaly jsut use it for the switching and dont even use the onboard amp) I LOVE it (for such purpose)
