Roohster
Ah I see (I think), do you mean that I might have adjusted the curtain/filer before calibrating?
If so, no I don't think I did.
Also just spotted in your pictures, your results graphs were for the centre but you were dragging the curtain back for the front not the centre.Ok, I did that:
Doesn't that just ignore the frequencies above 1k though?
My centre results look "off" across the whole range.
(Thanks for your patience. Sorry about all the questions, first time I've used MultEQ/Audyssey)
Drink coffee?!?Interesting, what does a calibrator for to an audio system beyond what you can do with the mic etc?
For me the, after numerous attempts, the Audyssey never gave me satisfying results in my room. The calibrator using his positional advice, equipment, ears and more importantly years of experience has given me an exemplary sound.Interesting, what does a calibrator for to an audio system beyond what you can do with the mic etc?
Is it not recommended to tweak the sub via the amp settings?To get rid of the eco display turn off the on screen display bit just for eco in the General/eco option menu.
not sure about the other osd can you grab the config screen shot for it, for me I thought it was either on or off tbh
just tweak the sub to your liking but adjusting the level manually or maybe moving it’s position or phase slightly
My Denon AVR-4500H is going on a open A/V rack, do you think I need a Aircom S6? mmmmI've had my 4500 a couple of days now and loving it so far
After much faffing with Audyssey and MultEQ it's sounding amazing.
Prior to this I'd had a string of Pioneers so I was expecting some differences, but... wow.
I'd always noticed a slight "hole" in the surround field midway down the side walls, but that has completely gone now.
The "steering" also seems really precise. I watched Midway last night and the numerous flyovers and dogfights showed seamless panning.
The one tiny thing I've yet to get to my satisfaction is the sub, it seems a tiny bit lacking but that could just be a case of tweaking it by a couple of dB.
I was also told the 4500 could run hot so I got one of these, an Aircom S6, seems to do a great job.
I have another question that I've been unable to find an answer for, regarding the on-screen display:
When I watch a BluRay, the info appears on screen when I adjust the volume... but not on any other source (SKY Q, Nvidia Shield). Any ideas?
Oh and ... is there any way to get rid of the "eco/energy bar" on screen (eco is turned off)?
I didn’t bother with it as mine was in an open space. Gave me zero issuesMy Denon AVR-4500H is going on a open A/V rack, do you think I need a Aircom S6? mmmm
Why it only saves something like ~30 watts?Also I would run eco mode on auto. So when it’s running low volume it’s running eco and when you turn it up the power kicks in.
Me neither, I do have one but found it a little distracting in my lounge, also what temperature is right for the amp? I’m not sure tbh. Just because I think it’s hot doesn’t mean it’s not the optimal heat for the amp to operate at.I didn’t bother with it as mine was in an open space. Gave me zero issues
I didn’t like the sound, so then when searching read this and a few other articles which ultimately put me off :-
Nothing. The 4500 will make the internal adjustmentsGulp Most of my speakers are 4-ohms..... anything I should watch out for?
My Jamo speakers are 4 ohms and the Prime Elevations are 8 ohms. Problem?
How about the sub? You said manually increase the volume. Is it not recommended to increase the volume via the amp?To get rid of the eco display turn off the on screen display bit just for eco in the General/eco option menu.
