Plymouthboy
I moved my Front Towers, part of my MA Bronze 6AV10 5.1 speaker setup, a few days ago so thought it a good idea to run Audyssey for some new recommended settings, I don't necessarily use them but they can be a good guide & then tweak until the ear's are relatively happy. Following my reading of past posts on speaker settings, and what a potential minefield that can be, I set all the speakers at Small with Crossovers that I tinker with but recently I was reading that good settings were Sub=120, Towers=80, Centre & surrounds=100. I changed to these settings but then moved the Towers & as said ran Audyssey. Now to my query, Audyssey changed the Crossovers to Front=Full Band, Centre & Surround=60, so if I now change the Crossovers back to my preferred settings as above will this throw out the Speaker Levels that Audyssey has recommended as I assume Audyssey has matched the Crossovers & Speaker Levels to be balanced? There does not seem to be the ability for the owner to set the Crossovers & then ask Audyssey to match the remaining settings to your chosen Crossovers or have I missed something? It would appear that I have little choice but to just return to trial & error until the old earholes are happy.
Thanks in anticipation for any replies.
