MartinGH1369
Hello there. I've got a an issue with my Denon AVR that I was hoping someone here might be able to help with.
Every now and then the AVR will make a really loud popping sound but the sound goes through the speakers, it's not the physical AVR that makes the sound. This sound can be incredibly loud. The weird thing about it is that when it does make this noise it launches the Audyssey setup screen. I've tried running the Audyssey setup but this hasn't stopped the issue. I've tried new HDMI and speaker cable to see if this helped; it didn't.
I've tried with the sub on and off/disconnected, this made no difference. It doesn't matter what the source is, they all do it.
It's not an issue I can record to show you as I can go for hours of watching something with no problem but then it will do it over and over with no warning.
As far as I can tell it's not an over heating issue, the AVR is well ventilated on all sides and doesn't feel hot to the touch, plus I'm yet to see any kind of warning signal.
I'm a bit stumped, can anyone offer advice or a fix please?
