Question Denon AVR-x2500 or 3400?
Discussion in 'AV Receivers & Amplifiers' started by Andrew Rice, Jul 14, 2018.
Tags:
  1. Andrew Rice
    Andrew Rice
    Dec 14, 2014
    161
    2
    43
    Cambridge
    +124
    I'm looking to upgrade to a £500ish avr and noticed these 2 are the same price at Richer Sounds. Is there any particular difference or obviously better model or any others I should be considering? It's mostly film based viewing but some music and PS4 usage.
    Cheers, Andy
  2. andym81
    andym81
    Nov 13, 2016
    652
    43
    GB
    +135
    What setup do you have
  3. Andrew Rice
    Andrew Rice
    Dec 14, 2014
    161
    2
    43
    Cambridge
    +124
    Dali Zensor 3 and Dali centre with 1's as surrounds. Oppo 203 and LG b6 telly. Wish I'd waited for B7 but thats another story. My present avr is a sony 1030 from a few years ago and ive never really liked it. Oh and an old REL sub which i keep low cos im in the middle of three flats. My room is quite big about 20 x 30 feet.
  4. andym81
    andym81
    Nov 13, 2016
    652
    43
    GB
    +135
    Personally I'd go for the 3400. Has slightly more power, which you wouldn't really notice but has the has audessey xt32. Give it a few months and the 2500 will be £300ish.
  5. Andrew Rice
    Andrew Rice
    Dec 14, 2014
    161
    2
    43
    Cambridge
    +124
    Thanks for reply I was tempted by the richer sounds email offer for the 2500 then saw the 3400 at the same price. I might hold on.
  6. Rambles
    Rambles
    Jul 14, 2004
    10,442
    167
    UK
    +2,151
    The 3400 is definitely a better buy, there is a comparison of the different models on this website (scroll down):
    AVR-X3400H | Multichannel amplifier with 3D sound
    As well as having a better version of Audyssey, the 3400 has a few more extra features, including that it will be getting via a firmware update for eARC (enhanced ARC) it also has support for dual subwoofers, and pre-outs for adding external amplification
    However, for music listening one of the Marantz models would be better than the Denon's.
  7. andym81
    andym81
    Nov 13, 2016
    652
    43
    GB
    +135
    The x3400 might drop to £500 at some point. Have you considered the x2400 it's £325 at RS
  8. Andrew Rice
    Andrew Rice
    Dec 14, 2014
    161
    2
    43
    Cambridge
    +124
    Yup I need to look into this. I always get a bit gungho when I see what's supposed to be a deal. Thanks guys i'll investigate
  9. YEHBABY
    YEHBABY
    Aug 26, 2012
    396
    46
    +138
    3400h is a no brainer. Always buy last years better model at a reduced price. Unless there is some killer feature in the new model, which isn't the case here.
  10. mushii
    mushii
    Apr 3, 2003
    2,240
    116
    Stoke On Trent
    +1,200
    3400 is an excellent buy.
