Robbie2003ie
Established Member
Denon AVR-X2000 keeps turning on and off, I think the issue only started after I got Sky Q, so not sure if the extra heat is causing the issue.
See attached pic, I previously had my satbox instead of Sky Q. It doesn't feel that hot when it turns off and on and it was working fine for about 18months in this position with my Satbox.
I checked all speaker connections and reseated them all, also did a reset of the amp and replaced the HDMi cable going from HDMi Arc out on amp to Arc connection on Samsung TV.
When I changed the cable it worked with restarting for about 2 days and then all of a sudden it happen again. Nothing in the enviorment has changed. Just can't get my head around it.
The only other thing I can think it maybe is the speaker cable going into the amp, some of them have been twisted and turned and im wondering cas the copoper cable been broke and may need to cut the ends off and re-twist them?
Hope someone can let me know if they have had this issue wqith this amp or any amp for that matter and what the issue was?
THanks in advance,
BobbyT28
THanks in advance,
BobbyT28
